customize SensorMonitor
Goodmorning,
I’ve customize Sensor Monitor. I need, in the context menu, hide some voices. In detail, I need to hide ‘Show Alarms’, ‘Acknowledge Alarms’, ‘Disable Alarms’ etc… or if you can’t hide them, is possible override default behavior?
Thank’s
Francesco
In the map these are the default commands, you cannot change or suppress this default behavior.
