DatabaseException - AddBank fail - Errors storing or creating database
Hi Team,
I am facing DatabaseException when launching the XProtect Management Client with a new MIP custom driver I’ve written. I’ve tried reinstalling the VMS Suite as well.
Below are the relevant logs:
MediaDb:
2024-03-04 14:52:55.199-08:00 [     4] INFO       - ******************************* Starting logger *******************************
2024-03-04 14:52:59.705-08:00 [    37] INFO       - ApplyConfiguration()
2024-03-04 14:52:59.709-08:00 [    37] INFO       - ApplyConfiguration() ... done
2024-03-04 14:52:59.770-08:00 [    37] INFO       - ApplyConfiguration()
2024-03-04 14:52:59.771-08:00 [    37] INFO       - ApplyConfiguration() ... done
2024-03-04 14:52:59.809-08:00 [    60] INFO       - AddBank(), Directory: C:\Users\teja.moolamalla\Documents\MediaDatabase\d2d4cc7c-4166-403f-98da-00f6e8649767; Storage id: d2d4cc7c-4166-403f-98da-00f6e8649767; Alternate id: 4e4a0263-c302-42e2-9ecb-fec276694b99
2024-03-04 14:52:59.839-08:00 [    60] INFO       - AddBank() ... Exception: VideoOS.Database.DatabaseException: Cannot create a file when that file already exists.
,  ---> VideoOS.Database.ConnectionException: NmDatabase::CmClientConnection::AddBank (line C:\w1\2e333172d4710577\prod\lib\src\Client\ClientConnection.cpp, 653): Error adding bank 'C:\Users\teja.moolamalla\Documents\MediaDatabase\d2d4cc7c-4166-403f-98da-00f6e8649767' to database! ---> VideoOS.Database.ConnectionException: NmDatabase::CmServerClient::AddBank (line C:\w1\2e333172d4710577\prod\lib\src\Server\ServerClient.cpp, 651): Error adding bank 'C:\Users\teja.moolamalla\Documents\MediaDatabase\d2d4cc7c-4166-403f-98da-00f6e8649767' to database! ---> VideoOS.Database.DatabaseException: NmDatabase::BankLoader::AddBankInternal (line C:\w1\2e333172d4710577\prod\lib\src\Core\BankLoader.cpp, 274): Error adding bank to database! ---> VideoOS.Database.DatabaseException: C:\w1\2e333172d4710577\prod\lib\src\Server\DatabaseStorage.cpp(line 677): Error ensuring that the parent directory for a storage exists. ---> VideoOS.Database.DatabaseException: NmFile::MakeSingleDirectory (line C:\w1\102e09352e4040b6\prod\lib\src\File\win32\File-OSD.cpp, 1686): Error making new directory 'C:\Users\teja.moolamalla\Documents'! ---> VideoOS.Database.DatabaseException: NmFile::MakeSingleDirectory (line C:\w1\102e09352e4040b6\prod\lib\src\File\win32\File-OSD.cpp, 1686):  : Cannot create a file when that file already exists.
   --- End of inner exception stack trace ---
   at VideoOS.Database.Connection.AddBank(String directory, String alternateId, String masterPassword)
   at VideoOS.Recorder.MediaDb.AddDatabase(StorageConfigurationBanks config, Guid storageId, Guid bankId, String storagePath, String folderName, RawDbChannel channel)
2024-03-04 14:52:59.846-08:00 [    60] INFO       - Storage availability changed. Id: d2d4cc7c-4166-403f-98da-00f6e8649767; Available: False
RecorderEngine:
2024-03-04 14:52:59.253-08:00 [    33] INFO       - Initializing media database, inProcess=True
2024-03-04 14:52:59.253-08:00 [    34] INFO       - RecorderModule: LoadConfigurationFromDisk
2024-03-04 14:52:59.254-08:00 [    34] INFO       - Loading cached recording server configuration
2024-03-04 14:52:59.488-08:00 [    34] INFO       - Loading cached security configuration
2024-03-04 14:52:59.534-08:00 [    33] INFO       - Media database initialized
2024-03-04 14:52:59.543-08:00 [    34] INFO       - Using cached configuration
2024-03-04 14:52:59.545-08:00 [    34] INFO       - Configuring license module
2024-03-04 14:52:59.548-08:00 [    34] INFO       - License module configured
2024-03-04 14:52:59.548-08:00 [    34] INFO       - Configuring rule processor
2024-03-04 14:52:59.692-08:00 [    34] INFO       - Rule processor configured
2024-03-04 14:52:59.695-08:00 [    38] INFO       - Applying recording server configuration
2024-03-04 14:52:59.696-08:00 [    39] INFO       - Configuring audio message manager
2024-03-04 14:52:59.697-08:00 [    37] INFO       - Configuring media database, inProcess=True
2024-03-04 14:52:59.697-08:00 [    40] INFO       - Starting patrolling controller
2024-03-04 14:52:59.698-08:00 [    39] INFO       - Audio message manager configured
2024-03-04 14:52:59.699-08:00 [    41] INFO       - Starting status module
2024-03-04 14:52:59.702-08:00 [    42] INFO       - Starting smart search module
2024-03-04 14:52:59.703-08:00 [    43] INFO       - Starting driver event listener
2024-03-04 14:52:59.704-08:00 [    44] INFO       - Starting driver services
2024-03-04 14:52:59.705-08:00 [    42] INFO       - Smart search module started
2024-03-04 14:52:59.705-08:00 [    44] INFO       - Driver services started
2024-03-04 14:52:59.708-08:00 [    45] INFO       - Starting SNMP module
2024-03-04 14:52:59.715-08:00 [    40] INFO       - Patrolling controller started
2024-03-04 14:52:59.717-08:00 [    43] INFO       - Driver event listener started
2024-03-04 14:52:59.794-08:00 [    37] INFO       - Media database configured
2024-03-04 14:52:59.805-08:00 [    38] INFO       - Driver manager - load driver. Hardware id: 7a4f886f-79d5-48df-915d-31a0c58884b0, Name: Machine name (localhost)
2024-03-04 14:52:59.843-08:00 [    35] INFO       - Unhandled MediaDb event: FAILURE_EVENT__ADDING_BANK_FAILED
2024-03-04 14:52:59.878-08:00 [    41] INFO       - Status module started
2024-03-04 14:52:59.878-08:00 [     4] INFO       - Bank directory is unavailable "Local default" (path: C:\Users\teja.moolamalla\Documents\MediaDatabase)
DeviceHandling
2024-03-04 14:52:59.973-08:00 [    38] INFO       - ******************************* Starting logger *******************************
2024-03-04 14:53:02.986-08:00 [    74] INFO       - 19a6448f-bc89-4293-9245-6cd52d10c77e  Machine name (localhost) - First camera  Starting frame group media db consumer (table: 19a6448f-bc89-4293-9245-6cd52d10c77e)
2024-03-04 14:53:02.986-08:00 [    74] INFO       - 19a6448f-bc89-4293-9245-6cd52d10c77e  Machine name (localhost) - First camera  Creating performance counter for device frame group media db consumer (table: 19a6448f-bc89-4293-9245-6cd52d10c77e)
2024-03-04 14:53:04.483-08:00 [    76] INFO       - 19a6448f-bc89-4293-9245-6cd52d10c77e  Machine name (localhost) - First camera  Device communication established
2024-03-04 14:53:05.473-08:00 [    77] ERROR      - 19a6448f-bc89-4293-9245-6cd52d10c77e  Machine name (localhost) - First camera  Bank is offline, thus not able to configure table: 19a6448f-bc89-4293-9245-6cd52d10c77e
2024-03-04 14:53:05.499-08:00 [    77] INFO       - 19a6448f-bc89-4293-9245-6cd52d10c77e  Machine name (localhost) - First camera  OnWriteGopStateChanged, failureWritingGop=True (table: 19a6448f-bc89-4293-9245-6cd52d10c77e)
To add to above, I don’t see any Documents\MediaDatabase folder created and I’m running 2023 R3 version.
Thanks!
