DBExporter : Xprotect Mangement Client 2019
HI,
I USE Xprotect Mangement Client 2019…
Because the end of registrations is signaled, when in reality it is only an interruption …
This causes the DBExporter method to fail with a failure?
TNX
You mentioned XProtect Management Client but the image you sent was Smart Client.
Are you using the MIP SDK and developing an integration?
Yes I’m developing an application for export via SDK(no plug-in) …
I use DBExporter Class, but this returns as if it were the end of the database …
In fact, at the point where it occurred, if it is evident with the smart client I notice the message of the photo …
TNX
Please ask again at Support Community for fixing your Smart Client export issue because this is a general issue on your site. You should get better help from the partners using the Support Community.
