Debug Plugin VS 2015
I am trying to debug my developed plugin on Event (Init), but program is not stop at this event. however I followed the one given advice in group (https://developer.milestonesys.com/s/question/0D53X00006INn8USAT/i-want-to-debug-the-demo-access-control-plugin-with-breakpointbut-i-launch-the-plugin-into-vs-2017-the-breakpoint-appears-with-a-warning-and-display-the-breakpoint-will-not-be-reached-yet-no-symbol-was-loadedthanks-for-help) But still not working. As earlier I use to debug, but after the new installation I am facing issue.
https://supportcommunity.milestonesys.com/s/article/debugging-techniques-for-Event-Server-plugins?language=en_US
You might have used this already. If so, please describe what you do and what you observe when you try to debug.
I am thankful to your given link. Now it’s working. Can you share the sample program that can show multiple camera in Listview then we select the single or specific camera and send to the Plugin to show that cameras in popup screen.
Please see ItemPickerForm, this might be helpful -
https://doc.developer.milestonesys.com/html/index.html?base=miphelp/class_video_o_s_1_1_platform_1_1_u_i_1_1_item_picker_form.html&tree=tree_search.html?search=itempickerform
