After a successful login to the XProtect system, the following line takes more than 5 seconds to execute:
VideoOS.Platform.Configuration.Instance.GetItem(serverID, cameraGuid, Kind.Camera);
This delay occurs only the first time immediately after login. Subsequent calls to GetItem() execute quickly.
This behavior is causing a noticeable delay in stream loading time, since the camera configuration must be retrieved before starting the stream.
Is this expected behavior after login, or is there any recommended way to avoid this initial delay?
