Detecting per-camera topic unsubscribe in AI Bridge IVA apps
We’re building a connectivity app on AI Bridge v3.0.1 that subscribes cameras to a metadata topic (ONVIF bounding boxes) and an analytics-event topic, pulls RTSP, runs inference in the cloud, and publishes detections back. Since inference is billed per stream,
we want to stop pulling video and inferring on a camera the moment its topic is unsubscribed in Management Client — not just when the camera itself is deleted.
What we’ve run into:
  1. cameras { communicationStatus } only tells us whether a camera exists and is online. It doesn’t expose whether our topic is currently subscribed for that camera.
  2. Unsubscribing our topic from a camera (Processing Server tab) doesn’t stop the RTSP stream on our side. We keep receiving frames from the streaming service indefinitely, even though the topic is no longer subscribed.
  3. We haven’t found any GraphQL query, documented or in the schema, that reports per-camera + per-topic subscription state.
Current approach:
We consume AI Bridge’s internal stream_subscriptions Kafka topic, which the proxy appears to re-affirm on a timer for each actively-subscribed camera+topic. When a path stops being re-affirmed past that interval, we treat it as unsubscribed and stop
pulling/inferring on that camera.
Question:
Is there a supported way to detect a per-camera topic unsubscribe that we’re missing? Is stopping RTSP consumption on unsubscribe expected to be handled client-side by the IVA app, or from the bridge side? Any pointers about what the suggested approach is, or whether the Kafka-based approach is an accepted pattern, would help us avoid running inference (we don’t want to add cost to a customer if it’s not needed) on cameras that are no longer subscribed.
Hi @andy_eyepop_ai,
In regards to your questions:
1 - “Is there a supported way to detect a per-camera topic unsubscribe that we’re missing?”
No, there’s no event on the AI Bridge that’s providing the unsubscription. Today, when unsubscribing the AI Bridge will stop communicating with the VPS Driver (Recording Server). The RTSP feeds will always be working regardless of the topic subscription (they are independent).
Best regards,
