Device configuration was updated outside of Configuration API. Refresh the configuration and try again
Getting exception in multithreaded/parallel sync app.
We sync parallelly/multithread all Hardware and Camera properties(Camera Tabs), Storage, Speakers, Output, etc.. between two recording server.
We get exception for Microphone Events, Camera Events, Input Events - “Device configuration was updated outside of Configuration API. Refresh the configuration and try again.”
/*Pseudo Code*/
We have two recording server on single management server having same Cameras
    Rec1 = ["Cam1", "Cam2", "Cam3"];
    Rec2 = ["Cam1", "Cam2", "Cam3"];
    camlisttosync = ["Cam1", "Cam2", "Cam3", ...] ;
    Thread[] thd = new Thread(total);
    thd[0] = new ThreadStart(syncfunction(camlisttosync[0]));
    thd[1] = new ThreadStart(syncfunction(camlisttosync[1]));
    thd[2] = new ThreadStart(syncfunction(camlisttosync[2]));
    thd[n] = new ThreadStart(syncfunction(camlisttosync[n]));
    wait for all thread to finish
    WaitAllThread(thd);
void syncfunction(String CameraName)
    Hardware PrimHw = findHW(Rec1, CameraName);
    Hardware SecHW = findHW(Rec2, CameraName);
    syncHardwareproperties(PrimHw, SecHW);
    syncSpeakerproperties(PrimHw, SecHW);
    syncOutputproperties(PrimHw, SecHW);
    syncInputproperties(PrimHw, SecHW);
void syncInputproperties(Hardware PrimHw, Hardware SecHW)
    InputEvent PrimInput = PrimHw.InputEventFolder.InputEvents.SingleOrDefault(x => x.Channel == 0);
    InputEvent SecInput = SecHW.InputEventFolder.InputEvents.SingleOrDefault(x => x.Channel == 0);
    try
        HardwareDeviceEventFolder PrimHDEF = PrimInput.HardwareDeviceEventFolder;
        if (PrimHDEF != null)
            foreach (HardwareDeviceEvent PrimHDE in PrimHDEF.HardwareDeviceEvents)
                HardwareDeviceEvent SecHDE = null;
                SecHDE = SecInput.HardwareDeviceEventFolder.HardwareDeviceEvents.SingleOrDefault(x => x.DisplayName == PrimHDE.DisplayName);
                if (SecHDE != null)
                    int iIndex = 0;
                    foreach (HardwareDeviceEventChildItem PrimHDECI in PrimHDE.HardwareDeviceEventChildItems)
                        HardwareDeviceEventChildItem SecHDECI = SecHDE.HardwareDeviceEventChildItems.ElementAt(iIndex++);
                        if (SecHDECI != null)
                            SecHDECI.Name = PrimHDECI.Name;
                            SecHDECI.Enabled = PrimHDECI.Enabled;
                            SecHDECI.Description = PrimHDECI.Description;
                            SecHDECI.EventUsed = PrimHDECI.EventUsed;
                            SecHDECI.EventIndex = PrimHDECI.EventIndex;
		// Saving the modified changes
                SecHDE.Save(); //exception here "Device configuration was updated outside of Configuration API. Refresh the configuration and try again."
    catch (Exception exp)
    try
        // Saving changes
        SecInput.Save();
/*Pseudo Code*/
Thanks,
Vega Support
You cannot do this in parallel. Even if you “just” have two Management Clients you will get the same message if you try to change the configuration in the same “area” at the same time.
