Device works in ONVIF Test Tool but not in Milestone XProtect
I am trying to develop a proof of concept ONVIF server application that will work with Milestone. The UDP/RTP video playback works with the ONVIF Device Test Tool, but in XProtect it fails to do the handshake properly. I’m sure the problem is on my side but I ran out of debugging options so I’m asking for help here.
In the Milestone device handling logs I see “Camera 1 Device communication error (OpenMediaStreamException). Error: Unable to open media stream”.
I’m attaching a sample Wireshark capture of adding the device.
I first posted here https://supportcommunity.milestonesys.com/s/question/0D50O00005bUSTT/device-works-in-onvif-test-tool-but-not-in-milestone-xprotect and they redirected me to this forum.
Thanks a lot !
Francois
I am sorry, you were in the right forum the first time because there is no support for doing Onvif device integration in the MIP SDK.
I suggest however that you talk with our Camera Partner team.. https://www.milestonesys.com/community/become-a-partner/technology-partner-program/
