DialogLoginForm duplicates Server address and User name in .NET Framework 4.8.
For example, if you log into http://192.168.0.1/, the next time you log in http://192.168.0.1/http://192.168.0.1/ is shown. The same behavior occurs with User name.
Thank you for this report. I am wondering if you see the same issue when you use .NET Framework 4.7.
Can you please try .NET Framework 4.7 and tell us what you see?
The issue does not occur with 4.7.1 or 4.7.2.
Milestone Development will start investigating this issue.
Thank you for testing using .NET Framework4.7, please use it until we know what is going on with .NET Framework4.8.
We are not able to reproduce this issue, could you please tell us what kind of user you use? Basic user or Windows user? And please tell us what sample you are using.
We decided to use the older Framework rather than troubleshoot further. Thanks anyway.
