Hello, this is partner company Markany.
In the future, the Korean government needs to install most VMS systems on Linux servers because it will use Linux server instead of Windows server for VMS system.
So we are developing gateways to allow your VMS system to work on Linux.
I am currently using the C ++ language SDK of Windows Server for the VMS system integration. If there is an SDK available for the API or JAVA language available on the Linux system, is it possible to support it?
Thank you.
