Drag n' Drop in Multiwindow ViewandLayout ?
Is there a possibility, to get the dragdrop event of an empty viewandlayout item located in a multiwindow ?
It works nice with an imageview containing an “dropbutton” in a background plugin. (Modified ActiveElementsOverlay )
In this button I get this event, no problem. But the disadvantage of this solution is, that a camera must be already switched on the view, so that the imageview with the button is created. Afterwards I can drag and drop everything on this button. Is there any other possibility to get the event e.g. on the drop down bar on thr bottom of the view ?
Second best solution would be a dragdropevent e.g. in the titlebar a mutliwindow with just one view.
Unfortunately no, there is no ways to get the drag’n’drop event of an empty viewandlayout item located in a multiwindow.
Thank you for the fast answer ! So I have to live with my second best solustion and don’t waste more time with trying.
Hello, has there been any changes to this recently? We also need to be able to drag&drop a camera GUID into an empty view tile.
