Edge Storage
we have a centralized system through which we directly record the flow of our cameras. Also, every camera has SD Card on board, to let EDGE Storage work. Currently, EDGE Storage automatically fills the remaining gaps that are created if the centralized recording system is offline.
Sometimes happens that our data flow is not the best, so you can translate it in low framerate or bad quality images, contrary to the image quality contained in EDGE Storage.
At this point we are interested to replace the centralized recordings (BAD QUALITY ONE) with the HD Quality recordings stored in the EDGEStorage. Or, at least, export the HD Quality video images on a separated project, or time span, playable using SmartClient.
I need to give my operator the instrument to choose if he wants to see the bad quality images or the HD Quality Video Images, in that period of time.
Is there any chance to solve this problem? Thanks community!
