I have written a script to automate moving Axis cameras to a new subnet. The part of the script that changes the device IP and gateway setting works just fine but I can’t get it to update Milestone using Set-VmsHardware. All of the fields (current IP, new IP, new gateway, username, password, and camera ID) are in a CSV file. Here is the script I am testing:
# Prompt the operator for the CSV file path and file name
$csvFilePath = Read-Host -Prompt "Enter the path and file name of the CSV file"
# Read CSV file
$cameras = Import-Csv -Path $csvFilePath
# Prompt for the log file location
$logFilePath = "C:\temp\CameraUpdateLog.log"
Add-Content -Path $logFilePath -Value "IP and Gateway Update Script Run: $(Get-Date)"
foreach ($camera in $cameras) {
$cameraIP = $camera.Address
$newIP = $camera.NewIPAddress
$newGateway = $camera.NewDefaultGateway
$username = $camera.Username
$password = $camera.Password
$camname = $camera.Name
# Convert password to secure string and create PSCredential object
$securePassword = ConvertTo-SecureString -String $password -AsPlainText -Force
$credential = New-Object System.Management.Automation.PSCredential ($username, $securePassword)
# URL to update IP and Gateway
$url = "http://${cameraIP}/axis-cgi/param.cgi?action=update&Network.IPAddress=$newIP&Network.DefaultRouter=$newGateway"
try {
# Set the new IP and Gateway using Digest Authentication
$response = Invoke-WebRequest -Uri $url -Credential $credential -Method GET -UseBasicParsing
$message = "Success: IP and Gateway for camera $camname at $cameraIP updated to IP: $newIP, Gateway: $newGateway."
Write-Host $message
Add-Content -Path $logFilePath -Value $message
# If IP change was successful, update Milestone
$hardwareId = $camera.Id
# Get the hardware object based on the hardware ID
$hardware = Get-VMSHardware | Where-Object { $_.Id -eq "$hardwareId" }
if ($hardware) {
try {
# Update the hardware IP address in Milestone
Set-VMSHardware -Hardware $hardware -Address $newIP
$milestoneMessage = "Milestone updated for camera $($camera.Name) with new IP $newIP."
Write-Host $milestoneMessage
Add-Content -Path $logFilePath -Value $milestoneMessage
} catch {
$milestoneError = "Failed to update Milestone for camera $($camera.Name) with new IP ${newIP}: $($_.Exception.Message)"
Write-Host $milestoneError
Add-Content -Path $logFilePath -Value $milestoneError
} else {
$errorNoHardware = "Hardware ID $hardwareId not found in Milestone for camera $($camera.Name)."
Write-Host $errorNoHardware
Add-Content -Path $logFilePath -Value $errorNoHardware
} catch {
$errorMessage = "Failed to update IP and Gateway for camera $($camera.Name) at ${cameraIP}: $($_.Exception.Message)"
Write-Host $errorMessage
Add-Content -Path $logFilePath -Value $errorMessage
I keep getting the following error:
Failed to update Milestone for camera (camera name) with new IP (x.x.x.x): Exception calling "Save" with "0" argument(s): "Exception of type 'VideoOS.Platform.Proxy.ConfigApi.ValidateResultException' was thrown."
I tried running Set-VmsHardware manually as well and the full error is
At C:\Program Files\WindowsPowerShell\Modules\MilestonePSTools\24.1.27\MilestonePSTools.psm1:9406 char:25
+ $hw.Save()
+ CategoryInfo : NotSpecified: (:) [], ParentContainsErrorRecordException
+ FullyQualifiedErrorId : ValidateResultException
If I run Get-VmsHardware it shows the device has the new IP address
However it doesn’t change / update in the Management Client or reconnect to the device or reconnect the video stream.
Any suggestions on what I’m doing wrong or what I need to change?
