"Error reading from stream!" error message. with StartExport()
We are getting a pretty generic error message on a StartExport.
Server is Corporate 2022 R2
SDK version is 21.2(one version behind currently).
We are planning on putting the StartExport into a loop so that if we get this error, we will try some number of re-attempts.
can you provide any further insight as to what ‘Error reading from stream!’ indicates?
Sorry. I meant to have ‘Error reading from stream!’ in this post.
Edited from ‘Error writing to stream!’ to ‘Error reading from stream!’
Firstly, please verify to use the newest SDK.
Also, is this Smart Client or standalone? Do you get the same error using the unmodified sample?
Standalone – https://doc.developer.milestonesys.com/html/index.html?base=samples/componentsamples/exportsample/readme.html&tree=tree_2.html
SC- https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/scexport/readme.html&tree=tree_1.html
