It is the same MediaLiveService project that was built from the sample code that Milestone MIP SDK has. Attaching the same here.
It was found to NOT be working on this setup:
- Milestone 2018 R2 installed on machine with this config:
System Information
Time of this report: 6/11/2019, 18:18:51
Machine name: VMS\_WM3
Operating System: Windows Server 2012 Standard 64-bit (6.2, Build 9200) (9200.win8_ldr_escrow.190502-1700)
Language: English (Regional Setting: English)
System Manufacturer: IBM
System Model: IBM System x3650 M4: -\[7915N5A\]-
BIOS: -\[VVE142DUS-1.73\]-
Processor: Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz (12 CPUs), ~2.1GHz
Memory: 8192MB RAM
Available OS Memory: 8004MB RAM
Page File: 6306MB used, 5408MB available
Windows Dir: [C:\\Windows](file:C:/Windows)
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
- It was found to be working on this setup
Milestone 2018 R3 installed on this machine:
System Information
Time of this report: 6/11/2019, 18:28:54
Machine name: DESKTOP-04FGM26
Machine Id: {A8A79955-4C7E-41D7-B3ED-440DFAA417B3}
Operating System: Windows 10 Pro 64-bit (10.0, Build 17763) (17763.rs5\_release.180914-1434)
System Manufacturer: Dell Inc.
System Model: PowerEdge R630
BIOS: Default System BIOS (type: BIOS)
Processor: Intel(R) Xeon(R) CPU E5-2603 v4 @ 1.70GHz (12 CPUs), ~1.7GHz
Memory: 32768MB RAM
Available OS Memory: 32674MB RAM
Page File: 26908MB used, 10630MB available
Windows Dir: [C:\\WINDOWS](file:C:/WINDOWS)
DirectX Version: DirectX 12
User DPI Setting: 96 DPI (100 percent)
Miracast: Not Available
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.17763.0001 64bit Unicode
