Error states not licensed when trying to get events from the plugin I am developing. I am using the free 1-8 camera XProtect Essential+ 2023 R2 with License M01-C07-232-01 Experation says Unrestricted. I am using yoru Demo Access Control Simulator Plugin from GitHub, along with your DemoServer Application.
I get the same issue when using the Plugin I am creating. How can I get events to show up so I can test the “rules” in the Management Applicaton?
License will expire if not activated, will start with a grace period but will expire. Also Access Control has a requirement of XProtect Express+ or better. I believe that is the cause of you not seeing the rules..
https://www.milestonesys.com/community/business-partner-tools/xprotect-comparison-tools/product-comparison-tool/
You might be able to sign up as a technology partner and be entitled to a free test license. Read about it and apply here - https://www.milestonesys.com/partners/become-a-partner/technology-partner/
I have an idea that you are working for a Technology Partner, if my idea is correct you can write to partners@milestonesys.com for guidance on this..
