Dear Sir / Madam,
We received some complain from our customer regarding the video quality issue. After investigation, we find below warning and error message are frequently shown in our system recording server log file. Would you please help to explain the details normally what is the root caused the issue, and give us some suggestion how to solve the problem? or any reference doc can help us to analysis and understand the system health status based on the information captured in the log file. Thanks.
Unable to add one or more frames to the frame collector (Logged only once a minute). Error code = 1
Unable to add one or more frames to the frame collector (Logged only once a minute). Error code = 2
Unable to add one or more frames to the frame collector (Logged only once a minute). Error code = 3
Device communication error (NoDataException). Error: GetMediaDataBlock returned no data.
Pipeline 1 - Frames received back or equal in time, lastest: 19/08/2021 14:31:27.387 current: 19/08/2021 14:31:21.730
FrameGrpConsumer.WriteGop() - Frames received back or equal in time, lastest: 19/08/2021 14:31:27.387 current: 19/08/2021 14:31:27.136
Regards,
ZhangWei
