Error writing to stream while recordings export
Hi!
I am using DBExporter to export recordings from Milestone.
After updating Milestone version from 2020 R2 to 2020 R3 it started failing sometimes with error (LastError = 1, LastErrorString = Error writing to stream). Could you guide about this error’s meaning?
The exception object has a GetCompleteErrorDescription() method that may shed some light on what happened. Can you tell us what it contains?
For clarity; is both the XProtect VMS and the MIP SDK 2020 R3?
It is failing sometimes; do you detect any pattern? Do you have ideas on what makes it fail? Consider things like the disk running full, writing to a network share that might experience interruptions or similar.
