I am having issue login to XProtect Management Client 2017 R2 and i do not see any error beside check surveillance server credentials after install not working for mobile server. I have reinstall 5 times, no luck, I am doing this on Win10 64 bit
when i go to http://localhost:80
i am getting
Service Unavailable
HTTP Error 503. The service is unavailable.
I believe it means that the IIS is not installed for some reason. Perhaps the installation log will reveal something. As the focus on this developer forum is on developing solutions with the MIP SDK please use the Support Community instead. https://force.milestonesys.com/support/MccSupportCommunity
Did you ever find a solution on how to resolve this issue?? I have the same issue on our 2018R2, cannot get the Mobile client credentials to work. Only Smart client locally. Thanks
