Greetings,
do you have experience with establishing communication with Milestone Open Network Bridge via ONVIF or Milestone SDK?
It’s known that it’s possible to connect with applications like VLC or ONVIF Device Manager, however, those aren’t usable for integration purposes.
We have the following problem with using for example MIP Component integration Live Viewer template. After questionable autorization to MS Bridge and selecting a camera – nothing is shown and after a while, an error “connection lost to server” appears, for which MS Bridge log contains no entry. Attempting various login attempts (as well as different feasible ports 80, 580 etc.) using ONVIF client library also fails as well as using ONVIF web-discovery library functions.
