Event Server - Event message not known (Alarm Command Protocol was used to create the Event and the Alarm)
So I’m trying to reverse-engineer this.
First, I registered an Analytics Event and used it to trigger an Alarm on a Specific Source Camera using XProtect Management Client.
Second, I used the GetAlarmLines (using Alarm Command Protocol) and inferred the Id of the created Alarm and used it as in as Input to Get request of the Alarm Command Protocol and found the fields that should be populated so that I can use the Add request.
Find http request below for which I got 200 OK status:
POST /Central/AlarmServiceToken HTTP/1.1
Host: 192.168.1.104:22331
Content-Type: text/xml
SOAPAction: http://videoos.net/2/CentralServerAlarmCommand/IAlarmCommandToken/Add
<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope
xmlns:SOAP-ENV=“http://schemas.xmlsoap.org/soap/envelope/
xmlns:SOAP-ENC=“http://schemas.xmlsoap.org/soap/encoding/
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance
xmlns:xsd=“http://www.w3.org/2001/XMLSchema
xmlns:ns7=“http://schemas.microsoft.com/2003/10/Serialization/Arrays
xmlns:ns8=“http://schemas.datacontract.org/2004/07/System.Collections.Generic
xmlns:ns5=“http://schemas.microsoft.com/2003/10/Serialization/
xmlns:ns6=“urn:milestone-systems”
xmlns:ns4=“http://schemas.datacontract.org/2004/07/VideoOS.Platform.Proxy.Alarm
xmlns:ns1=“http://tempuri.org/
xmlns:ns3=“http://videoos.net/2/CentralServerAlarmCommand”>
SOAP-ENV:Body
<ns3:Add>
  <ns3:token>TOKEN#7791e16c-da28-4e44-b307-25d0556f917f#desktop-47um62b//ServerConnector#</ns3:token>
  <ns3:alarm>
    <ns6:EventHeader>
      <ns6:ID>0c335dc6-757b-4d7e-95d6-8022bf1b8a06</ns6:ID>
      <ns6:Timestamp>2020-08-10T15:59:44Z</ns6:Timestamp>
      <ns6:Type>MyType</ns6:Type>
      <ns6:Priority>1</ns6:Priority>
      <ns6:PriorityName>High</ns6:PriorityName>
      <ns6:Name>MyAlarm03</ns6:Name>
      <ns6:Message>MyAnalyticsEvent03</ns6:Message>
      <ns6:CustomTag>TagFromXML</ns6:CustomTag>
      <ns6:Source>
        <ns6:Name>Avigilon 1.0-H3-B1 (192.168.0.222) - Camera 1</ns6:Name>
        <ns6:FQID>
          <ns6:ServerId>
            <ns6:Type>XPCORS</ns6:Type>
            <ns6:Hostname>desktop-47um62b</ns6:Hostname>
            <ns6:Port>7563</ns6:Port>
            <ns6:Id>16760179-b8db-4d19-9ad5-09a9d04f5489</ns6:Id>
            <ns6:Scheme>http</ns6:Scheme>
          </ns6:ServerId>
          <ns6:ParentId>16760179-b8db-4d19-9ad5-09a9d04f5489</ns6:ParentId>
          <ns6:ObjectId>69dee837-08a0-4686-87b8-d3ec58961a1a</ns6:ObjectId>
          <ns6:FolderType>0</ns6:FolderType>
          <ns6:Kind>5135ba21-f1dc-4321-806a-6ce2017343c0</ns6:Kind>
        </ns6:FQID>
      </ns6:Source>
      <ns6:MessageId>1ff1da10-8a9a-4c96-85c5-5ff0803382e0</ns6:MessageId>
    </ns6:EventHeader>
    <ns6:Description>SOAP Event</ns6:Description>
    <ns6:Location>Gate-1</ns6:Location>
    <ns6:State>1</ns6:State>
    <ns6:StateName>New</ns6:StateName>
    <ns6:CategoryName></ns6:CategoryName>
    <ns6:AssignedTo></ns6:AssignedTo>
    <ns6:RuleList>
      <ns6:Rule>
        <ns6:ID>5a0762ef-bc4f-484e-bbef-57b39c833261</ns6:ID>
        <ns6:Type>4547f085-8b68-4639-826f-8722afb0ffc5</ns6:Type>
      </ns6:Rule>
    </ns6:RuleList>
    <ns6:ReferenceList>
      <ns6:Reference>
        <ns6:FQID>
          <ns6:ServerId>
          </ns6:ServerId>
        </ns6:FQID>
      </ns6:Reference>
    </ns6:ReferenceList>
    <ns6:Vendor>
      <ns6:Name>Avidbeam Technologies</ns6:Name>
    </ns6:Vendor>
  </ns3:alarm>
</ns3:Add>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Now when using the Message MyAnalyticsEvent03 to send an Analytics Event to the Event Server, I get Warning: Event message not known. Any idea what’s wrong here?
Also, I do not see the Event or Alarm listed in XProtect Management Client. Is this how it supposed to be?
Kind Regards,
Eslam
UPDATE (post can not be edited):
Well, I believe this increased the number of Alarms, but did not create a new event and bound it to a source camera through an Alarm. Is there is away to achieve this using the Alarm Command Protocol? Or is the only way available is through the Management Client?
Thanks!
To set up an AnalyticsEvent (definition) and an Alarm Definition is configuration job that is done in the Management Client (if not from MIP SDK code).
The Alarm Command Protocol does not contain any configuration job code.
The Configuration API is the API for doing configuration of the XProtect VMS including setting up Analytics Event (definition) and Alarm Definition.
Please see -
https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/intro_configurationapi.html&tree=tree_4.html
https://doc.developer.milestonesys.com/html/index.html?base=samples/configapiclient.html&tree=tree_2.html
Note.
It is possible to submit an alarm to XProtect without having an Analytics Event (definition) or Alarm Definition.
Please see this knowledge base article: https://developer.milestonesys.com/s/article/Create-an-alarm-from-a-MIP-SDK-based-application Note that the article refers to a sample and that sample does not use the protocols directly.
In general Milestone recommends to have an Alarm Definition to allow the administrator to control the use of the alarms and the knowledge base article explains the reasoning behind this.
