Events not received from AnalyticsEventTriggerViaLibrary
When using the AnalyticsEventTriggerViaLibrary sample, events are not received in Smart Client. Using the TriggerAnalyticsEventXML sample from the protocol samples works perfectly. AnalyticsEventTriggerViaLibrary sample does not report any error. Any idea what would cause the SDK component to not work as expected?
The most probable cause is a port blocked by firewall or similar.
Use this knowledge base article for troubleshooting. (https://force.milestonesys.com/support/articles/en_US/How_To/Ports-for-alarms-from-Milestone-Event-Server-service)
