Events & State WebSocket stays "subscribed" but delivers zero events, even after fixing API Gateway's IDP secret registration (XProtect 2025 R3)
**Environment**
XProtect Corporate, **2025 R3**, Management Server + Event Server + API Gateway on the same box.
**Summary**
We have a client that authenticates fine, and whose REST calls through the API Gateway work perfectly (`/api/rest/v1/sites`, `/hardware`, `/cameras` all return real data). The Events & State WebSocket connects, completes the upgrade, and our client logs `connectionState: subscribed`. No error, no disconnect. But **we never receive a single event frame**, no matter what we trigger on the server.
**What we’ve ruled out**
- **Not a “service down” problem.** Event Server, Log Server, and Data Collector were each independently restarted by our site’s Milestone admin, live, one at a time. None of the four changed anything.
- **Not the API Gateway being generally broken.** Verified with Milestone’s own official verification steps: a real service-account login through the gateway returns a genuine bearer token, and a real authenticated `/api/rest/v1/sites` call through the same gateway returns real data.
- **Not a client-side timing miss.** We ran four separate 5-minute watch windows (polling our own event buffer every 2s) across three different real triggers on the server (an initial generic test, an online/offline test, and a recording server stop/start done twice). Cross-checked our watch window against the Management Client’s own System Logs: the recording server’s stop (4:54:24 PM) and start (4:55:59 PM) both land *inside* one of our watch windows (16:50:52–16:56:01) to the second. All four windows: connection stayed `subscribed`, zero events received.
- **Not “the events aren’t actually firing.”** Confirmed independently in System Logs, Audit Logs, *and* Event Server’s own log file that these events are real and dispatched on the server side, at the same timestamps we were watching.
**What we found and fixed — but it wasn’t sufficient**
We found this in the API Gateway’s own log (`gateway.log`):
ERROR - VmsTokenProvider.HandleSecret: Secret not found, try doing a re-registration
ERROR - VmsTokenProvider.HandleAndValidateSecret: IDP secret is invalid.
    Registration of API Gateway may be required
ERROR - DynamicProxyConfigurationService.ConfigureEventServerProxyWithRetryAsync:
    Failed to configure event server route | Retrying after 60s
Our reading: the API Gateway has its own identity/secret for authenticating itself to the IdP (separate from any client-facing service account), and that secret was missing/invalid — which meant it could never complete `ConfigureEventServerProxyAsync`, the step that wires up the Event Server route the WebSocket depends on.
**Fix applied:** removed the stale Gateway Service registration (Management Client → Tools → Registered Services) and recycled the `VideoOS ApiGateway AppPool` in IIS. This time, the gateway log showed a successful re-registration (an earlier attempt at the same recycle had produced no new log activity at all — this one clearly took effect).
**Result after the fix:** we forced a fresh client reconnect (to avoid reusing any pre-fix token/session) and re-ran the watch-window test against two more real triggers. Same outcome as before: connects, stays `subscribed`, **zero events delivered**.
**Where that leaves us**
The break is confirmed to sit *downstream* of “API Gateway can’t register with the IdP” — that specific problem is fixed and confirmed to have taken effect. Something else in the Event Server → API Gateway → WebSocket relay still isn’t passing events through, even though:
- the gateway’s own IdP registration is healthy,
- REST traffic through the same gateway works,
- the WS handshake/subscription itself succeeds and stays up,
- and the events are demonstrably firing on the Event Server side.
**What we’re asking**
1. Beyond `VmsTokenProvider`/IDP-secret registration, is there a **separate** registration or subscription step in the Event Server ↔ API Gateway relay for the Events & State WebSocket specifically (as opposed to REST proxying), that a stale/incomplete state could still be blocking even after the IDP secret fix?
2. What should we be looking for in **Event Server’s own log** (as opposed to `gateway.log`) for this specific handoff — is there a known log line that confirms/denies whether Event Server is actually pushing to the API Gateway’s relay for a given subscription?
3. Is there a known issue in 2025 R3 in this area, or a diagnostic/reset step (beyond what’s already in the API Gateway install docs) that specifically targets the Event Server-side half of this relay rather than the Gateway/IdP-side half we already fixed?
@00520000004X6QSAA0 @Dave_Muller
The fact that the WebSocket reaches and remains in subscribed state indicates that the subscription request itself has been accepted. That would normally suggest the initial API Gateway / IDP registration issue is no longer blocking the Events & State connection.
Regarding your questions:
  1. Is it expected that the subscription stays active but no events are received?
Yes. A subscription can remain active even when zero events are delivered. The subscribed state only confirms that the server accepted the subscription. It does not guarantee that matching events are being published to that subscription.
  1. What should we verify next?
I would recommend checking:
Whether the subscription contains filters that may exclude the events being generated.
Whether the user/account used for the subscription has sufficient permissions to access those event sources.
Whether a known event (for example a manually triggered Generic Event) is visible through the Events & State API.
Whether Event Server logs show that the events are being generated and forwarded to subscribers.
As a test, try creating the broadest possible subscription and then trigger a simple event that you know is generated in the system.
  1. Could this indicate a product issue?
Possibly, but only after ruling out filtering, permissions, and event-source scope.
If:
  • the WebSocket remains connected,
  • the subscription is accepted,
  • events are clearly present in the system,
  • the subscription is intentionally broad,
  • and no events are ever delivered,
  • then it would be valuable to collect logs from the involved components and compare the behavior with one of the Events & State API samples.
The behavior you describe is not what would normally be expected from a healthy subscription receiving matching events, so additional investigation would be warranted if the checks above do not identify the cause.
Reference:
https://doc.developer.milestonesys.com/apis/eventsandstate/
