Dear Forum,
Lately while developing our plugin, we started getting this exception in the Smart Client while debugging the smart client with Visual Studio 2019.
(Start external program: [C:\Program](file:C:/Program) Files\Milestone\XProtect Smart Client\Client.exe)
I have tried remove all plugins from MIPPlugins folder and this is also happens.
************** Inner Exception **************
Exception type:System.IO.FileNotFoundException
Exception message:Could not load file or assembly ‘ThinkGeo.MapSuite.ProductCenter, Version=10.0.0.0, Culture=neutral, PublicKeyToken=0828af5241fb4207’ or one of its dependencies. The system cannot find the file specified.
Exception source:ThinkGeo.MapSuite
Exception Target Site: ShowProductCenter
at ThinkGeo.MapSuite.ExtendedHelper.ShowProductCenter()
at ohM=.XRQ=.YhQ=(Boolean needToShowProductCenter)
at ThinkGeo.MapSuite.ValidatorHelper.CheckStatus()
at ThinkGeo.MapSuite.ValidatorHelper.CheckObjectIsNotNull(Object parameterObject, String parameterName)
at ThinkGeo.MapSuite.GeoCollection`1.set_Item(String key, T value)
at VideoOS.RemoteClient.Plugin.GisMap.ThinkGeoMap.ThinkGeoWpfMap..ctor()
… etc
************** System Info **************
Date and time: 8/3/2020 10:45:03 AM
Machine Name: MILESTONESERVER
Processors count: 6
OS version: Microsoft Windows NT 6.2.9200.0
64 bit OS: True
64 bit process: True
IP address: ****************
Current user: MILESTONESERVER\Administrator
is there some fix for this matter? how can i track the exception origin?
Thank you,
Or
