Exported video cannot play in Smart Client - Player (Plug-in is not available)
I have got a Samsung SNF-7010 setup in Smart Client with Samsung FishEye dewarping plugin. After exporting the video to inculed XProtect Smart Client - Player, video will not able to play and said plug-in is not available.
You can make the SC Player work by adding the plugin into the exported plugin folder. The process is the same as initially installing the plugin where you extract the contents of the download from Samsung into the Smart Client folder only you would export into the exported project plugin folder.
Note that the image will not be ‘Dewarped’ within the Smart Client player. This feature request has been submitted as well as a feature request to have the Plugin exported with the exported project.
Regards,
Chris Benefiel
If this adequately answers your question select ‘Best Answer’ to close out the conversation. Thank You!
I had similar issue with Xprotect smart client 2014 version, I can’t play the video exported with any other folder.
Please help with information on how to play the video with other video players.
I also have a problem of not able to unchecked the checked box on the exported path from CD burner to only Disk.
Thanks in anticipation.
I am guessing that there is a better chance that partners active on the Support Community will be able to help with a Smart Client usage question.
https://force.milestonesys.com/support/MccSupportCommunity
The Developer Forum is focussed on development of integrations.
