F44 Axis Cameras show unsync times when played in recording mode
I’m connected to 4 F44 Axis Cameras (all 4 are connected to 1 device).
When running a recorded video, I see the times of the Cameras is not syncronized, with 5-10 seconds difference between each other.
(The F44 Axis Cameras are connected to the same box).
Did you even encounter this problem? Is it a problem with the stream or with the cameras? Any actions I can do in order to check this weird behavior?
Thanks.
