Failed to add a site to hierarchy
I’m trying to set up a federated site, but I’m encountering an issue. I’ve followed the suggestions in this thread [link] and I’ve checked the following:
  • Can the primary server resolve the hostnames of the secondary servers and can the secondary servers resolve the host name of the primary : YES
  • Are either management servers hard pressed for resources, CPU, memory or network : No, resources are sufficient
  • If you install a Smart Client on both management servers primary and secondary can the secondary log onto the primary and vice versa: YES, from both sides
  • Is the secondary service user added as an administrator on the primary and vice versa : YES, from both sides
  • If you have tried to customize the hostnames or IPs then check the tools - registered services - network settings and confirm that this is the address for the cluster or server you expect (this is often forgotten) : Checked
  • Check time/date and time zone is correct and expected for both sites : Checked
I’ve found that there are no log messages related to the federation on the secondary server, but there are some on the primary server, which are as follows:
01/07/2025 09:11:45 (pid 20684, tid 19892, 01/07/2025 00:11:45) 01/07/2025 00:11:45 [19892] WARNING - ConnectToSite: Server-to-Server connection error. Failed to attach to site 'dc305208-e8c0-4611-92cd-b7a8f7cd323c' from home site 'ED4E967A-E774-4D06-A290-2A52D07F12CE','512SHZY010597' using the target's configured addresses . Exception='VideoOS.Management.VmoClient.UserNamePasswordException: Failed to connect, check the user name and password. ---> System.ServiceModel.Security.SecurityNegotiationException: 호출자가 서비스에 의해 인증되지 않았습니다. ---> System.ServiceModel.FaultException: 인증에 실패했기 때문에 보안 토큰에 대한 요청을 충족할 수 없습니다.
   위치: System.ServiceModel.Security.SecurityUtils.ThrowIfNegotiationFault(Message message, EndpointAddress target)
   위치: System.ServiceModel.Security.SspiNegotiationTokenProvider.GetNextOutgoingMessageBody(Message incomingMessage, SspiNegotiationTokenProviderState sspiState)
   --- 내부 예외 스택 추적의 끝 ---
Server stack trace:
   위치: System.ServiceModel.Security.IssuanceTokenProviderBase`1.DoNegotiation(TimeSpan timeout)
   위치: System.ServiceModel.Security.SspiNegotiationTokenProvider.OnOpen(TimeSpan timeout)
   위치: System.ServiceModel.Security.WrapperSecurityCommunicationObject.OnOpen(TimeSpan timeout)
   위치: System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)
   위치: System.ServiceModel.Security.CommunicationObjectSecurityTokenProvider.Open(TimeSpan timeout)
   위치: System.ServiceModel.Security.SymmetricSecurityProtocol.OnOpen(TimeSpan timeout)
   위치: System.ServiceModel.Channels.SecurityChannelFactory`1.ClientSecurityChannel`1.OnOpen(TimeSpan timeout)
   위치: System.ServiceModel.Security.SecuritySessionSecurityTokenProvider.DoOperation(SecuritySessionOperation operation, EndpointAddress target, Uri via, SecurityToken currentToken, TimeSpan timeout)
   위치: System.ServiceModel.Security.SecuritySessionSecurityTokenProvider.GetTokenCore(TimeSpan timeout)
   위치: System.IdentityModel.Selectors.SecurityTokenProvider.GetToken(TimeSpan timeout)
   위치: System.ServiceModel.Security.SecuritySessionClientSettings`1.ClientSecuritySessionChannel.OnOpen(TimeSpan timeout)
   위치: System.ServiceModel.Channels.ServiceChannel.OnOpen(TimeSpan timeout)
   위치: System.ServiceModel.Channels.ServiceChannel.CallOpenOnce.System.ServiceModel.Channels.ServiceChannel.ICallOnce.Call(ServiceChannel channel, TimeSpan timeout)
   위치: System.ServiceModel.Channels.ServiceChannel.CallOnceManager.CallOnce(TimeSpan timeout, CallOnceManager cascade)
   위치: System.ServiceModel.Channels.ServiceChannel.EnsureOpened(TimeSpan timeout)
   위치: System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
   위치: System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
   위치: System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
   위치: System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
   위치: System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
   위치: VideoOS.Management.VmoClient.Proxy.IServerService.GetServerVersion()
   위치: VideoOS.Management.VmoClient.ConnectionManager.UpdateServerVersionLegacy()
   위치: VideoOS.Management.VmoClient.ConnectionManager.Connect()
   위치: VideoOS.Management.VmoClient.Internal.SiteConnector.SiteConnectionThread(InternalSiteConnectionInfo siteConnectionInfo)'
