Windows OS version: Win Server 2022
Milestone Product: Express+
Milestone Version: 2025R1
Our Camera Driver version: Driver Drop6
Steps
- Set camera on “Https only” model.
- Manual add camera.
- Click Our Driver tree and select both single and multi sensor driver
- input camera IP address and click next button
- the device add process can’t complete as attached video.
When we select only one specific driver, the camera addition is successful in Milestone.
When we choose auto detect(both drivers are selected), camera addition is failed in Milestone. Please refer attached video clip for camera addition failed case.
We analyzed the logs for failed case as attached(Device_Addition_2026-01-08_19036_non_working.txt), we saw CreateContainer API called from Milestone Driver Frame work as CreateContainer(https://10.78.208.230:0/) where https port no came as “0” which is not correct and actual https port is 443. So camera communication fails with the uri https://10.78.208.230:0/onvif/device_service to fetch capabilities from the camera.
when we select single driver with out auto detect option , CreateContainer(https://10.78.208.230/) comes with correct https uri and able to add the our camera to Milestone system.
Could you please analyze the attached logs and advice us for further steps.
