Fails to export MKV Video with Audio
In the XProtect Expert 2017 R2 version I am not able to export MKV video with audio in the software itself.
Export AVI video with audio or separate audio works fine. Solution requires to use MKV format.
I assume it is a bug. Isn’t it? Could you try is it work for you?
Works for me. This is not a question about MIP SDK development so please ask the Support Community. https://force.milestonesys.com/support/MccSupportCommunity
Thank you for your answer Bo, I will use Support Community :slight_smile:
