How does Milestone’s cache of a users’ personal ACM config work? Right now it seems sporadic… How long is the cache kept for? Is there any way to force it to fetch a new config before it expires? Etc.
I’m running into an issue with my plugin because if I change a users’ permission level in the access control https://speedtest.vet/ system https://vidmate.bid/ (ie what doors they are https://wordtopdf.ltd/ allowed to see/open), which doesn’t change the global ACM config (ie if I refresh the config from mgmt client it says no changes), that change is not visible in the smart client for the user until the cache is expired.
thankyou
