FFMpeg Milestone Open Network Bridge Error 401
I am executing the following command:
ffmpeg -rtsp_transport tcp -i “rtsp://test:Password@172.17.4.2:554/vod/3c0b0475-53b0-4c67-82e3-290107acfc0b” -loglevel debug -ss 00:00:00 -frames:v 1 aa.jpg
And I am encountering the following authentication error.
ffmpeg version 6.0-full_build-www.gyan.dev Copyright (c) 2000-2023 the FFmpeg developers
built with gcc 12.2.0 (Rev10, Built by MSYS2 project)
configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libaribb24 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libjxl --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libvpl --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
libavutil 58. 2.100 / 58. 2.100
libavcodec 60. 3.100 / 60. 3.100
libavformat 60. 3.100 / 60. 3.100
libavdevice 60. 1.100 / 60. 1.100
libavfilter 9. 3.100 / 9. 3.100
libswscale 7. 1.100 / 7. 1.100
libswresample 4. 10.100 / 4. 10.100
libpostproc 57. 1.100 / 57. 1.100
Splitting the commandline.
Reading option ‘-rtsp_transport’ … matched as AVOption ‘rtsp_transport’ with argument ‘tcp’.
Reading option ‘-i’ … matched as input url with argument ‘rtsp://test:Password.@172.17.4.2:554/vod/3c0b0475-53b0-4c67-82e3-290107acfc0b’.
Reading option ‘-loglevel’ … matched as option ‘loglevel’ (set logging level) with argument ‘debug’.
Reading option ‘-ss’ … matched as option ‘ss’ (set the start time offset) with argument ‘00:00:00’.
Reading option ‘-frames:v’ … matched as option ‘frames’ (set the number of frames to output) with argument ‘1’.
Reading option ‘aa.jpg’ … matched as output url.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option loglevel (set logging level) with argument debug.
Successfully parsed a group of options.
Parsing a group of options: input url rtsp://test:Password.@172.17.4.2:554/vod/3c0b0475-53b0-4c67-82e3-290107acfc0b.
Opening an input file: rtsp://test:Password.@172.17.4.2:554/vod/3c0b0475-53b0-4c67-82e3-290107acfc0b.
[tcp @ 00000148ac6d9140] No default whitelist set
[tcp @ 00000148ac6d9140] Original list of addresses:
[tcp @ 00000148ac6d9140] Address 172.17.4.2 port 554
[tcp @ 00000148ac6d9140] Interleaved list of addresses:
[tcp @ 00000148ac6d9140] Starting connection attempt to 172.17.4.2 port 554
[tcp @ 00000148ac6d9140] Successfully connected to 172.17.4.2 port 554
[rtsp @ 00000148ac6c12c0] method DESCRIBE failed: 401 Unauthorized
[rtsp @ 00000148ac6c12c0] CSeq: 3
Date: Wed, Jan 08 2025 11:31:46 GMT
WWW-Authenticate: Digest realm=“RtspServerLibrary”, nonce=“r5uyRrqAosKnHcev7jV2kyNBuyPyf6rZ”, algorithm=“MD5”
WWW-Authenticate: Digest realm=“RtspServerLibrary”, nonce=“r5uyRrqAosKnHcev7jV2kyNBuyPyf6rZ”, algorithm=“SHA-256”
rtsp://test:Password.@172.17.4.2:554/vod/3c0b0475-53b0-4c67-82e3-290107acfc0b: Server returned 401 Unauthorized (authorization failed)
What is the issue?
Please look at :
https://developer.milestonesys.com/s/article/changes-digest-authentication-RTSP-service-in-2021-R1-troubleshooting?t=1651655384508
and
https://supportcommunity.milestonesys.com/s/question/0D53X0000AGEVOoSQP/disable-sha256-authentication-in-open-network-bridge?language=en_US
Kind Regards,
Svetlana
I have changed the registry to the indicated values, but the error persists.
Reading option ‘-i’ … matched as input url with argument ‘rtsp://test:Dorlet2024.@172.17.4.2:554/vod/3c0b0475-53b0-4c67-82e3-290107acfc0b’.
Parsing a group of options: input url rtsp://test:Dorlet2024.@172.17.4.2:554/vod/3c0b0475-53b0-4c67-82e3-290107acfc0b.
Opening an input file: rtsp://test:Dorlet2024.@172.17.4.2:554/vod/3c0b0475-53b0-4c67-82e3-290107acfc0b.
[tcp @ 000001c413479140] No default whitelist set
[tcp @ 000001c413479140] Original list of addresses:
[tcp @ 000001c413479140] Address 172.17.4.2 port 554
[tcp @ 000001c413479140] Interleaved list of addresses:
[tcp @ 000001c413479140] Starting connection attempt to 172.17.4.2 port 554
[tcp @ 000001c413479140] Successfully connected to 172.17.4.2 port 554
[rtsp @ 000001c4134612c0] method DESCRIBE failed: 401 Unauthorized
[rtsp @ 000001c4134612c0] CSeq: 3
Date: Fri, Jan 10 2025 09:00:09 GMT
WWW-Authenticate: Digest realm=“RtspServerLibrary”, nonce=“aG4nx27foxCW0N5qqYutudYaoKKSrxBT”, algorithm=“MD5”
rtsp://test:Dorlet2024.@172.17.4.2:554/vod/3c0b0475-53b0-4c67-82e3-290107acfc0b: Server returned 401 Unauthorized (authorization failed)
Fermin
Do you experience same issue with VLC or Onvif Device Manager?
Have you added your user to the Open Network Bridge via tray manager?
Which version of ONB you use?
Do you experience same issue with VLC or Onvif Device Manager? Yes
Have you added your user to the Open Network Bridge via tray manager? Yes
Which version of ONB you use? 24.1a
Please check RTSP logs for errors (those should be in [C:\ProgramData\Milestone\Milesotne](file:C:/ProgramData/Milestone/Milesotne) Open Network Bridge\Logs)
Is it possible you 've changed password, after adding the user in tray manager? If that is the case please re-add
I removed and re-added the user to Open Network Bridge, and it is working correctly.
Thank you very much.
