Find and stop Exception related to playbackcontroller
OnClose of SmartClient I get the same exception every time.
I tried to debug playbackcontroller. Also place many try/catches to ignore the error.
Where to set a break-point to examine the code? Or, a good clue from the forum would be great.
Here is the Exception …
Exception type:System.InvalidOperationException
Exception message:Collection was modified; enumeration operation may not execute.
Exception source:mscorlib
Exception Target Site: ThrowInvalidOperationException
at System.ThrowHelper.ThrowInvalidOperationException(ExceptionResource resource)
at System.Collections.Generic.Dictionary`2.ValueCollection.Enumerator.MoveNext()
at VideoOS.RemoteClient.Application.MIP.Manager.SCClientControl.ReleaseAllPlaybackControllers()
at VideoOS.RemoteClient.Application.MIP.Manager.SCEnvironmentManager.HandleApplicationStateChangedLogoff()
at VideoOS.RemoteClient.Application.MIP.Manager.SCEnvironmentManager.SmartClientLoggedOffHandler()
at VideoOS.RemoteClient.Application.Application.Logout()
at VideoOS.RemoteClient.MainApp.MainWindow.Window_Closing(Object sender, CancelEventArgs e)
at System.Windows.Window.OnClosing(CancelEventArgs e)
at System.Windows.Window.WmClose()
at System.Windows.Window.WindowFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.PublicHooksFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
************** System Info **************
Date and time: 6/16/2025 8:41:43 AM
Machine Name: ATC-DG-02
Processors count: 8
OS version: Microsoft Windows NT 10.0.19045.0
64 bit OS: True
64 bit process: True
Please see this recent forum thread on the same exception.
https://developer.milestonesys.com/s/question/0D5bH00001Ayt7HSAR/i-am-getting-error-while-closing-smart-client
I hope you might find other similarities beyond the exception and it can help you find a solution. Please let e know what you find…
Thank Bo. The link you provided helped a lot.
Here is some of the code that got exiting the SmartClient to work for me!
public static List _playbackFQIDList = new List();
public override void Init()
_playbackFQID = ClientControl.Instance.GeneratePlaybackController();
if (_playbackFQID != null)
_playbackFQIDList.Add(this._playbackFQID);
public class LatestAlarm3Definition : PluginDefinition
public override void Close()
try
for (int ii = LatestAlarm3ViewItemWpfUserControl._playbackFQIDList.Count - 1; ii >= 0; ii–)
if (LatestAlarm3ViewItemWpfUserControl._playbackFQIDList[ii] != null)
ClientControl.Instance.ReleasePlaybackController(LatestAlarm3ViewItemWpfUserControl._playbackFQIDList[ii]);
LatestAlarm3ViewItemWpfUserControl._playbackFQIDList[ii] = null;
else
LatestAlarm3ViewItemWpfUserControl._playbackFQIDList.RemoveAt(ii);
catch (Exception)
David Gradwell
App-Techs Corporation
