I am using a RawLiveSource to stream data from cameras. With my current setup, which is predominantly using Axis Cameras (but I do have others), I receive the VideoStreamPacket sub format. Is it likely that I could receive the MultiPacket or VideoBlock formats? is it also a possibility that the format might change whilst streaming.
Did you read about the video formats here? – https://doc.developer.milestonesys.com/mipsdk/index.html?base=reference%2Fprotocols%2Fvideo_sub_formats.html&tree=tree_3.html
If you already did read this without finding an answer to your question I will consult an expert here at Milestone, and in that case forgive my asking..
Thanks for getting back Bo. Apologies, I did read the information regarding the generic byte data format but totally missed the information that answers my question, my bad!
