Generic driver to receive a UDP / h264 stream
Is there a generic driver available, which is able to receive a UDP broadcast h264 / mpegts stream?
Best regards,
Thomas
Universal driver uses RTP/RTSP to retrieve stream - but I dont think it supports broadcast (or multicast)
Is that the definitive answer? No broadcast / multicast reception? :slight_smile:
I have never tried but broadcast / multicast should be possible with RTSP in the Universal Driver.
I had a discussion with one of our experienced driver developers, and I might have been overly optimistic. I have the following statement after further discussion -
Milestone doesn’t support mpegts (Mpeg Transport Stream) in the Universal Driver currently.
OK. Thank you for the answer. It has been helpful in narrowing in on a solution. :slight_smile:
