Hiya,
I’m using the LiveContentEvent event for an audio device. In the event handler I get the LiveContentRawEventArgs parameter with the live content as a byte array. According to the documentation the first 32 or 36 bytes of the raw data byte array are a ‘GenericByteHeader (32 or 36) bytes specifying the following frame format and codec’.
Is there any documentation on the ‘GenericByteHeader’ format itself so that I can parse it correctly? I’ve looked through the documentation but cannot find anything.
