Get live stream with full resolution via RTSP
If I configure a camera to use a stream with lower resolution as “Default” and another stream with full resolution as “Record” on the Streams tab in the camera settings I get the desired result in Smart Client. I save bandwidth and processing on the client compared to viewing the live stream in full resolution. But I can still view the recorded video in full resolution when needed. This is especially important when viewing many cameras live at once.
Now I want to consume live video via Open Network Bridge (RTSP) in full resolution. When requesting the live stream (rtsp:///live/) I get the lower resolution, and when requesting the recorded stream (rtsp:///vod/) I get full resolution, as expected. When playing around with start time in the recorded stream request I almost get to live, but not quite. There is a delay of several seconds. I guess that is from writing and reading the video stream to and from storage. Is there another way to get the live stream in full resolution via RTSP?
Hi Magnus,
In Open Network Bridge you can request specific live stream like:
rtsp://[rtsp_server]:554/live/[camera_id]/[stream_id]
for more details please refer to Open Network Bridge documentation , section Use a media player to view a video stream
Thank you @Svetlana Ulyanova​! Using stream id, or number, worked perfectly.
