get status of a device
The goal is get the status of a device. I understood that the correct sequence in the case of basic Authenticarion and SSL is the following but not Work
This is the sequence:
  1. I create my Guid for InsstanceID for example:
97088254-afd7-4014-849e-4aadd5f91874
  1. I get the Token through the login method of the end point https: // /ManagementServer/ServerCommandService.svc
QUESTION:
<soapenv: Envelope xmlns: soapenv = “http://schemas.xmlsoap.org/soap/envelope/” xmlns: xpr = “http://videoos.net/2/XProtectCSServerCommand”>
<soapenv: Header />
<soapenv: Body>
<xpr: Login>
 <! - Optional: ->
 <xpr: instanceId> 97088254-afd7-4014-849e-4aadd5f91874 </ xpr: instanceId>
 <! - Optional: ->
 <xpr: currentToken> </ xpr: currentToken>
</ xpr: Login>
</ soapenv: Body>
</ soapenv: Envelope>
REPLY:
The answer is this:
<s: Envelope xmlns: s = “http://schemas.xmlsoap.org/soap/envelope/”>
<s: Body>
<LoginResponse xmlns = “http://videoos.net/2/XProtectCSServerCommand”>
 <LoginResult xmlns: i = "[http://www.w3.org/2001/XMLSchema-instance](http://www.w3.org/2001/XMLSchema-instance "http://www.w3.org/2001/XMLSchema-instance")">
  <RegistrationTime> 2020-11-23T12: 57: 07.213Z </RegistrationTime>
  <TimeToLive>
    <MicroSeconds> 14400000000 </MicroSeconds>
  </TimeToLive>
  <TimeToLiveLimited> false </TimeToLiveLimited>
  <Token>TOKEN # aae540bf-0bc3-4deb-9d02-354c13c64d52 # 4msvms // ServerConnector #</Token>
 </LoginResult>
</ s: Body>
</ s: Envelope>
  1. I get a deviceID via GetConfiguration of the end point https: // /ManagementServer/ServerCommandService.svc
QUESTION
<soapenv: Header />
<soapenv: Body>
<xpr: GetConfiguration>
 <! - Optional: ->
 <xpr: token>TOKEN # aae540bf-0bc3-4deb-9d02-354c13c64d52 # 4msvms // ServerConnector #</ xpr: token>
</ xpr: GetConfiguration>
</ soapenv: Body>
and from the content (only a part) of the answer I take a deviceid of a camera
<Recorders>
    <RecorderInfo>
     <Cameras>
       <CameraInfo>
        <CoverageDepth> 0 </CoverageDepth>
        <CoverageDirection> 0 </CoverageDirection>
        <CoverageFieldOfView> 0 </CoverageFieldOfView>
        <Description />
        <DeviceId>62f57c0d-44fc-4825-a285-89223a041729</DeviceId>
        <DeviceIndex> 0 </DeviceIndex>
        <GisPoint> POINT EMPTY </GisPoint>
        <HardwareId> 947df69a-96b0-4d8f-963e-02f116baf0f1 </HardwareId>
        <Icon> 0 </Icon>
        <Name> HikVisionGeneric (10.0.5.12) - Room 1 </Name>
        <RecorderId> 7e5750b6-3be2-4740-9247-f310a0f8f94c </RecorderId>
Now that I have the Token and the device ID I can use the GetCurrentDeviceStatus method from the End Point http:///recorderstatusservice/recorderstatusservice2.asmx
I ask the question:
<soapenv: Envelope xmlns: soapenv = “http://schemas.xmlsoap.org/soap/envelope/” xmlns: xpr = “http://videoos.net/2/XProtectCSRecorderStatus2”>
<soapenv: Header />
<soapenv: Body>
<xpr: GetCurrentDeviceStatus>
 <! - Optional: ->
 <! - Optional: ->
 <xpr: deviceIds>
  <! - Zero or more repetitions: ->
  <xpr: guid>62f57c0d-44fc-4825-a285-89223a041729</ xpr: guid>
 </ xpr: deviceIds>
</ xpr: GetCurrentDeviceStatus>
</ soapenv: Body>
But in response I get this error which I don’t understand what it means
<soap: Envelope xmlns: xsi = “http://www.w3.org/2001/XMLSchema-instance” xmlns: xsd = “http://www.w3.org/2001/XMLSchema” xmlns: soap = "http : //schemas.xmlsoap.org/soap/envelope/ ">
<soap: Body>
<soap: Fault>
 <faultcode> soap: Server </faultcode>
 <faultstring> Error processing message </faultstring>
 <detail>
  <ErrorNumber> 10000 </ErrorNumber>
 </detail>
</ soap: Fault>
</ soap: Body>
</ soap: Envelope>
Where did I go wrong
You will need to check the WebServer.log on the recorder for the specific error:
WebServer.Logger.LogError(“SOAPRequesthandlerBase.HandleRequest: Exception: {0}”, ex);”
Excuse me but what you are telling me is in the log file and where it is. Thank you
Milestone logs are here – [C:\ProgramData\Milestone\(service](file:C:/ProgramData/Milestone/(service) name) \Log.
Please note that ProgramData is a hidden folder.
I’m running into the same issue:
Here’s what the web server log shows when I try to make the GetCurrentDeviceStatus request, and yes my guid follows the format:
2021-04-11 20:40:01.559-05:00 [ 92] ERROR - SOAPRequesthandlerBase.HandleRequest: Exception: System.FormatException: Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx).
at System.Guid.GuidResult.SetFailure(ParseFailureKind failure, String failureMessageID, Object failureMessageFormatArgument, String failureArgumentName, Exception innerException)
at System.Guid.TryParseGuidWithNoStyle(String guidString, GuidResult& result)
at System.Guid.TryParseGuid(String g, GuidStyles flags, GuidResult& result)
at System.Guid..ctor(String g)
at VideoOS.Recorder.WebServer.SOAPStatus2RequestHandler.<>c.b__21_0(XmlNode n)
at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source)
at VideoOS.Recorder.WebServer.SOAPStatus2RequestHandler.HandleGetCurrentDeviceStatus(XmlNode node, String requestNS, XmlWriter responseWriter)
at VideoOS.Recorder.WebServer.SOAPStatus2RequestHandler.ExecuteFunction(XmlNode node, String requestNS, XmlWriter responseWriter)
at VideoOS.Recorder.WebServer.SOAPRequestHandlerBase.HandleRequest(IWebRequestReader requestReader)
2021-04-11 20:40:01.559-05:00 [ 92] WARNING - SOAPRequesthandlerBase.HandleRequest: SOAP exception, SOAP fault: <?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:xsd=“http://www.w3.org/2001/XMLSchema” xmlns:soap=“http://schemas.xmlsoap.org/soap/envelope/”>soap:Bodysoap:Faultsoap:ServerError processing message10000</soap:Fault></soap:Body></soap:Envelope>
I asked Milestone Development and they say that there is something wrong with GUID.
Maybe not serialized correctly if called from a self-made proxy.
Can you please verify if the GUID is correct?
