Getting 400 Bad Request error when requesting token from IDP
While we can validate that the API Gateway is responding and registered, the IDP Uri responds with a 400 Bad Request error.
Has anyone seen this and/or knows how to address what’s wrong?
To our knowledge, nothing besides our calls to the IDP/API Gateway is affected by this issue.
Just to add some info. We were able to connect with the 2022R2 APIs. It is since we upgraded to XProtect 2023R2 that we are now getting a HTTP 400 error. We did run the validation routine and it confirmed the URL to the endpoints was the same as 2022R2. We suspect the URL is not correct and that the validate routine is stale, providing us with the wrong URL to the new API endpoint.
It sounds like you are stuck here.. https://doc.developer.milestonesys.com/mipvmsapi/api/config-rest/v1/#section/Introduction/Get-started
Did you follow the guide? (or something else?)
There might be hints or ideas in this recent thread that started on another subject but then troubleshooting authentication.. https://developer.milestonesys.com/s/question/0D53X0000CfaMJVSQ2/camera-list-taking-too-long-via-getconfiguration
