Getting Error Code 28 on Mobile server
Hi Team,
I am getting error code 28 while logging into the Milestone Mobile Server. The Connect command is working, but I am getting this error during the login call. I have checked the appendix, and it says ‘Addresses not reachable.’ Could someone please elaborate on what the exact issue is here and how to fix it?
<?xml version="1.0" encoding="utf-8"?><Communication xmlns:xsd=" XML Schema " xmlns:xsi="``http://www.w3.org/2001/XMLSchema-instance``"><ConnectionId>02167047-7c89-44eb-87e1-3a8dba5e6bcb</ConnectionId><Command SequenceId="2"><Type>Response</Type><Name>LogIn</Name><InputParams /><OutputParams /><Items /><Result>Error</Result><ErrorCode>28</ErrorCode></Command></Communication>
Hi @rbuha,
Provided information is not enough to know the reason for failure.
Please try the following:
  • check Mobile Server log for errors. Check MIP SDK logs for errors. Check IDP logs for errors. Provide any relevant ones here.
  • try to login via Web Client (or Mobile Client) from the same host
  • if previous bullet works fine, compare your Login request with the one sent by Web Client
Regards,
Nikolay
