I am new to milestone. I trying to run the web example getting cors error. i already followed the instruction to enable cors with this link: https://developer.milestonesys.com/s/article/XProtect-Mobile-Server-app-on-different-server-CORS. But still getting error:
Access to XMLHttpRequest at ‘http://192.168.100.10/XProtectMobile/Communication’ from origin ‘http://localhost:5000’ has been blocked by CORS policy: Response to preflight request doesn’t pass access control check: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
logging.js:5898 Command Connect failed
(anonymous) @ logging.js:5898
p @ logging.js:5842
r.onreadystatechange @ logging.js:2598
XMLHttpRequest.send (async)
Request @ logging.js:2630
g @ logging.js:5817
XPMobileSDK.library.ConnectionRequest @ logging.js:5776
Connection.sendCommand @ logging.js:5381
Connection.Connect @ logging.js:3194
r @ XPMobileSDK.js:330
connect @ XPMobileSDK.js:296
connectToServer @ loginManager.js:44
logging.js:2630 POST http://192.168.100.10/XProtectMobile/Communication net::ERR_FAILED
