Getting screen resolution
Hi
If I get the available screens like so
List<Item> screens = Configuration.Instance.GetItemsByKind(Kind.Screen);
Is it possible to get the screen resolutions?
I use the screen fqid to open a floating window and would need to know how big I can make the window.
You can find resolution in screen[i].Properties with keys Size.Width and Size.Height
Freddy
Hm, the only key in Properties is “Id”
You are right, you need to use Window Properties, like this part of code:
    MultiWindowCommandData data = new MultiWindowCommandData();
    if (screens != null && screens.Count > 0)
      data.Screen = screens\[0\].FQID;
      List<Item> windows = Configuration.Instance.GetItemsByKind(Kind.Window);
      if (windows != null && windows.Count > 0)
        //             // Calcoli per le Dimensioni della Floating Windows
        //             int \_width = DefWindowWidth, \_height = DefWindowHeight;
        Dictionary<string, string> prop = windows\[0\].Properties;
        if (prop.ContainsKey("Size.Width") && prop.ContainsKey("Size.Height"))
          if (!int.TryParse(prop\["Size.Width"\], out \_width))
            \_width = DefWindowWidth;
          if (!int.TryParse(prop\["Size.Height"\], out \_height))
Freddy
But that looks like it will give me the size of a window that may or may not cover the entire screen.
