Getting the logged-in user of a message on the Event Server?
How do I correctly authorize a message in the ES when it comes from the SC or MC? Putting the SID into the message envelope isn’t safe: a low-privileged user could hand-craft the command with an admin SID, since the SID can be obtained by iterating over the users in the configuration.
So I wonder what the correct way is to get the SID from the real sender in order to perform the SecurityAccess.CheckPermission check.
With map/alarm actions this is clear, the TriggerCommand arrives with the sender as a Kind.User FQID that has the SID, but with normal MIP messaging I don’t get that. And I can’t trust the sender argument of PostMessage(message, destination, sender) either, because the client sets it itself, so anyone could just pass an admin FQID there.
Thanks!
The APIs on the Event Server will ensure that the calling user is allowed to make the call (sending the message) but there is unfortunately no way for plug-ins listening for messages to safely do specific authorization checks as the identity of the caller is not passed on.
Ok thanks
