Hardware events don't show in management client
I try to configure my Xprotect Expert system sending mail och motion. I’ve found this guide
(https://www.youtube.com/watch?v=vKwketwf4Jw)
but I’m missing the “Hardware input events”-menu item is missing in the menu in my installation.
Is this a Licensíng issue or what can I do?
The video guide is for the XProtect Professional portfolio (Enterprise, Professional, Express, Essential and Go), but you are using the XProtect Advanced (Corporate and Expert), which is a little different.
In the Management Client, for each device with inputs, you must define/add the events you want to use. These events can then be used from Rules.
