Hello guys. I'm new on Milestone SDk.. wondering if there is a link, post or something where I can learn how to expose REST endpoints using milestone SDK ... thanks for any comment.
My approach is to use VS 2017 to create a ASP Net web Application (Net FRamework)
thanks!!
Hi. Component samples may help you ;
https://doc.developer.milestonesys.com/html/index.html?base=samples/index_2.html&tree=tree_2.html
( Please click on each sample on the left side of the page when you see these samples.)
Hi. It would be possible to develop an ASP.Net solution that communicate with the Milestone VMS. You can use the component samples for your inspiration.
If you do not use ASP.Net an alternative solution is to develop an Event server plugin that exposes a REST interface.
Thanks a lot!
