Hello,We have a Linux based cloud service where we would like to add camera streams from Milestone.What would be the best/easiest way to access streams in Milestone? Should the cloud service connect to mobile server or straight to recording server.
Please keep in mind that I am not a coder and I am just trying to help integrators. Thank you in advance for your possible answers.
Best regards,
Vesa
I recommend using the Mobile SDK.
https://doc.developer.milestonesys.com/mipsdkmobile/
You will find working with the Mobile SDK easier but it is possible to make a direct integration that makes a login directly on the Server Command Service and retrieves video data directly from the Image Server service on the recording servers.
https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/intro_soap_protocols.html&tree=tree_3.html
Thanks Bo,
Where from I can download the Mobile SDK. I found some related threads but I guess I am not a technology partner so the link is not working:
https://developer.milestonesys.com/s/article/About-Milestone-software-development-Kit-SDK-download-link
Do you have another link?
Best regards,
Vesa
I can see the link failing, I will make sure to correct the article. Please use - https://www.milestonesys.com/community/developer-tools/sdk/download-sdk/
