Hi,how can I get the camera GPS positioning information in code? I was expecting to find it in the Camera Properties Dictionary under the location key, but that is always blank.
In order to get this information from the system you will have to use the Configuration API.
If you run the Config API Client sample you can see how the information is available.
Configuration API works for XProtect Corporate, Expert and Plus products, which happens to be the same products that support GPS positioning information.
