Hi I am New to Milesone integration,
Here is My code snippet for retrieving the camera info and saving to SQL;
      static public void CheckCameraChildren(Item parent)
  List<Item> itemsOnNextLevel = parent.GetChildren(); // This causes the configuration Items to be loaded.
  if (itemsOnNextLevel != null)
    foreach (Item item in itemsOnNextLevel)
      if(item.FQID.FolderType== [FolderType.No](https://FolderType.No))
        \_camera = item;
        Console.WriteLine(\_camera.Name);
        Console.WriteLine(\_camera.FQID.Kind);
        Console.WriteLine(item.FQID.ToString());
        using (DataClasses1DataContext dc = new DataClasses1DataContext())
          MILESTONE\_DATA mILESTONE\_DATA = new MILESTONE\_DATA();
          mILESTONE\_DATA.MILE\_SERVERNAME = \_camera.FQID.ServerId.ServerHostname;
          mILESTONE\_DATA.MILE\_SERVER\_ID = \_camera.[FQID.ServerId.Id](https://FQID.ServerId.Id);
          mILESTONE\_DATA.MILE\_SERVER\_HOSTNAME = \_camera.FQID.ServerId.ServerHostname;
          mILESTONE\_DATA.MILE\_SERVER\_PORT = \_camera.FQID.ServerId.Serverport;
          mILESTONE\_DATA.MILE\_SYSTEMTYPE = \_camera.FQID.ServerId.ServerType;
          mILESTONE\_DATA.MILE\_PARENTID = \_camera.FQID.ParentId;
          mILESTONE\_DATA.MILE\_FQID\_KIND = \_camera.FQID.Kind;
          mILESTONE\_DATA.MILE\_FQID\_OBJECTID = \_camera.FQID.ObjectId;
          mILESTONE\_DATA.MILE\_FQID\_FOLDERTYPE = \_camera.FQID.FolderType.ToString();
          mILESTONE\_DATA.MILE\_CAMERANAME = \_camera.Name;
          mILESTONE\_DATA.MILE\_CAMERAFQID = \_camera.FQID.ToString();
          dc.MILESTONE\_DATAs.InsertOnSubmit(mILESTONE\_DATA);
          dc.SubmitChanges();
      CheckCameraChildren(item);
And Here is how I retrieve from SQL and try send the message;
// Test Send Message
public static void SendCommandToMilestone()
  using (DataClasses1DataContext dc=new DataClasses1DataContext())
    var qry = from a in dc.GetTable<MILESTONE\_DATA>()
         where a.MILE\_SERVERNAME!=null
         select a;
    foreach (var item1 in qry)
      if (!string.IsNullOrEmpty(item1.MILE\_SERVERNAME))
        Guid \_serverGuid = new Guid(item1.MILE\_SERVER\_ID.ToString());
        Guid \_parentIDGUID = new Guid(item1.MILE\_PARENTID.ToString());
        Guid \_objectIDGUID = new Guid(item1.MILE\_FQID\_OBJECTID.ToString());
        Guid \_kind = new Guid(item1.MILE\_FQID\_KIND.ToString());
        VideoOS.Platform.ServerId serverId = new ServerId(item1.MILE\_SYSTEMTYPE, item1.MILE\_SERVER\_HOSTNAME, 7563, \_serverGuid);
        \_itemCamera = new Item(serverId, \_parentIDGUID, \_objectIDGUID, item1.MILE\_CAMERANAME, [FolderType.No](https://FolderType.No), \_kind);
        EnvironmentManager.Instance.PostMessage(new VideoOS.Platform.Messaging.Message(MessageId.Control.StartRecordingCommand), \_itemCamera.FQID);
        Console.WriteLine("Server Type ->{0}", serverId.ServerType);
        Console.WriteLine("Server id ->{0}", [serverId.Id](https://serverId.Id));
        Console.WriteLine("Parent ID ->{0}", \_parentIDGUID);
        Console.WriteLine("Object ID ->{0}", \_objectIDGUID);
        Console.WriteLine("Name ->{0}", item1.MILE\_CAMERANAME);
        Console.WriteLine("Folder Type From SQL and FolderType ->{0} {1}", item1.MILE\_FQID\_FOLDERTYPE, [FolderType.No](https://FolderType.No));
        Console.WriteLine("Kind ->{0}", \_kind);
        Console.WriteLine("Item FQID ->{0}", \_itemCamera.FQID.ToString());
        Console.WriteLine(\_itemCamera.ToString());
        Console.ForegroundColor = ConsoleColor.Yellow;
        Console.WriteLine(\_camera.ToString());
        Console.WriteLine("Cam FQID ->{0}", \_camera.FQID.ToString());
        Console.ResetColor();
Thank you for sharing your code. Do you have a question?
Yes sorry. I am creating a configuration tool for integration and need to store cameras user defined events and their associated data etc. In SQL.
I then have a serbice which checks certain criteria and then needs to trigger camera recording and user events etc from the data in the sql configurations
​ Cant seem to pass the corrext info to the trigger
II
