The problem is that in the control room with operators, if they want to visualize several cameras of one store, the BW consuption is too high. We have not found any way posible in which Milestone uses one H264 low resolution for a view with several cameras and high resolution H264 stream for a maximized camera. For some reason, Milestone provides MJPEG lower resolution if selected int the properties of the smart client.
There is a pluging called “Dynamic Stream” that performs this but is not working for us.
As we all know, MJPEG requires 4-6 times de H264 bitrate and I can not figure out why Milestone re-compresses the video to MJPEG instead of H264.
Does anyone has experience with this or with Dynamic Stream Selection plugin ?
Thanks a lot.
Juan.
