hide any tabs on SmartClient
Usually, We have showed the following tabs on SmartClient.
[live](javascript:void(0); “live”)
[playback](javascript:void(0); “playback”)
[sequence](javascript:void(0); “sequence”) Explorer
[alarm](javascript:void(0); “alarm”) Manager
Is it possible to hide any tabs (fx. hide the Playback tab) , using MIP SDK?
No. This cannot be controlled from the SDK. But you can do it in the Management Client in the Smart Client Profiles.
We appliciated your confirmation.
We refered to XProtect VMS 2017 R2 Administrator Manual.
“Smart Client Profiles” is available on the “Professional+” , isn’t it?
we’d like to know how to do it.
Yes, you can have up to 3 different Smart Client profiles in Professional+.
Explaining in detail how it is configured is beyond the scope of this forum, but it is a node of its own in the Management Client under “Client” top node and I would say it is fairly straightforward. Otherwise you will also find instructions in the manual.
