Currently, I’m working on modifying the SQL stored procedure (create_task_change_hardware_password) to set a custom password to be set on the camera hardware.
The problem I’m having is figuring out how the password in this stored procedure is encrypted - I suspect its encrypted using the key in the keys table from the SQL table but I am not sure what format. I am able to create my own example of the encrypted password by trying to change the hardware password via the management client - then checking the task table in the SQL table.
However - I would prefer to actually figure out the encryption mechanism being used here so I can use a script instead to inject my own custom password into the SQL stored procedure. Does anyone have any idea of how these passwords are encrypted?
